- 5:47 AM
- Jul 1, 2015
The alternator MUST be connected to a load, with field voltage applied, turning at given RPM. The Factory Service Manual shows the load test procedures. NEVER operate the alternator with the the output wire disconnected as the diodes will be damaged. IF the alternator shows no output, it is possible that the brushes may be worn out or the field voltage may not be present, due to a faulty regulator. Again, the service manual shows how to test for this possibility. DO YOU HAVE A FACTORY SERVICE MANUAL for your year and model? A great source of information......I just put it in a trickle charger last night. Yesterday when I took it for a drive to fill the tank and have the new alternator tested, before my post, I had it running for about a half hour. The ammeter show either discharge or right in the middle without much bounce like I had before the replacement.
I may need to figure out how to test the alternator from the alternator terminals instead of the battery, in guess... Then look at the voltage regulator.
BOB RENTON
