Sweeping to Rally gauge wiring
gregscu
New Member
2:44 AM
bc
Is there an adapter you can use from the sweeping gauge to rally gauge connections?
Nope. It takes a different harness for sure and depending on what model, it may take a different dash frame.
ok thanks
where is a good place to get a wiring harness?
ok thanks
You might find a good used harness here by starting a part wanted thread. It would be best to look through the threads and see if you can find information about the swap for your car before buying parts.
buy a new one from Yearone dont play with a used one not worth it. they are expensive but worth it.
Toolmanmike where at in Iowa?
