If the etching isn't too bad it might be easier just to smooth and polish the lens. You can use 400 - 600 - 1000 grit sandpaper then simichrome polish (or silver polish works too).
X2... it works with patience. If worse comes to worse, grab a chunka plexiglass and cut you another out. Going by the section of the post, you have a lense with a gentle curve. Make you something with a reverse curve to it to use as a support, and you can warm the plexiglass with a blow dryer or heat gun, curve it to fit the dash, press it firmly against the pattern and let it cool. You could actually make a vacuum table to draw it down with a little effort, but there's really no need to go that far unless you plan on using it more than one time.
