63fury500
- 4:05 PM
- Jun 19, 2016
- Beaver Dam, Wisconsin 53916
I have a new tci flex plate for mopars rb block,
Fits: 6-Bolt, Mopar, V8, 727/904
Flexplate, Internal Engine Balance, 2-Piece Rear Main Seal, SFI 29.1, Each
Rear Main Seal Style: 2-piece
Engine Balance: Internal
Flexplate Material: Steel
Safety Rating: SFI 29.1
Quantity: Sold individually.
Notes: Small bolt circle, 7/16 in. bolt, 6-hole forged crank.
If you need stock, stamped, or heavy-duty, TCI forged flexplates is your performance solution. TCI offers popular Chrysler, Ford, and Chevy applications. Their forged selection for Chrysler includes special counter balanced flexplates for neutral balance torque converters in cast crank applications that came with a counter balanced torque converter. For Ford applications TCI offers OEM-style small block plates built to precise standards with extra-thick welds to retain starter ring gear and are precision-balanced. Their Chevy stamped flexplates are built .035 in. thicker than stock from high-tensile strength materials with extra welding to help retain the starter ring gear and to withstand the stress of high-rpm engines and high-stall converters. Stock or mild performance, buzzing around at high rpms needs the confidence of TCI forged flexplates. sells for 80.00 ill take 50$
shipped to your door im in beaver dam wi
