..looks like the one from flexalite ( nylon fan ) ... afaik these fans work well..... The Jag Clutch is too weak, we need a heavyduty clutch for our Mopars...
unfortunatly these clutches are too "Long" ....
I don't know if this will help you or not. I'm running a clutch/fan assembly from an early 90's 360 w250 pickup. It's a 7blade fan 20". I'm running a 451 in a 72 satellite. I've had no issues, at any temp or situation. I only paid 35 bucks for it at pick n pull. The shroud is off an 85 Chrysler fifth ave. I hope this helps, I don't know what your peticuler situation is (clearance,cooling, etc). Take care Howard
