Texas Twister Fan
71_Duster
9:37 PM
Alberta
I can't run the stock clutch on my 440 Belvedere and the Jaguar clutch just isn't pulling enough air at idle.
Has anyone tried Maradyne's new texas twister fan?
..looks like the one from flexalite ( nylon fan ) ... afaik these fans work well..... The Jag Clutch is too weak, we need a heavyduty clutch for our Mopars...
unfortunatly these clutches are too "Long" ....
Greetings Juergen
I don't know if this will help you or not. I'm running a clutch/fan assembly from an early 90's 360 w250 pickup. It's a 7blade fan 20". I'm running a 451 in a 72 satellite. I've had no issues, at any temp or situation. I only paid 35 bucks for it at pick n pull. The shroud is off an 85 Chrysler fifth ave. I hope this helps, I don't know what your peticuler situation is (clearance,cooling, etc). Take care Howard
If cooling is your concern,forget any flex fan !!
