Throttle bracket and cable length?
19 69 GTX
1:22 AM
Working and throttle bracket and cable for my roadrunner. Putting eddy rpm intake on and was wondering what throttle bracket ill need. Im sure I need a taller than stock one. Also will the stock length throttle cable work . If not what length should I buy. Car was missing this stuff when I acquired it. I don't need a throttle bracket with a kickdown provision I have a 4 speed.
AR Engineering makes a wide selection of throttle brackets for different combinations. They're all available on Mancini's website. They also have a broad selection of throttle cable lengths - one size over stock should be sufficient. Pay attention when chosing to make sure you get the correct pedal end - the style switched at some point. And if you're missing any of the parts to attach it to the pedal make sure to get those at the same time.
