FOR SALE Throttle cables 60s 70s Charger Road Runner GTX Coronet Satellite
Moparparts
2:48 PM
PA
Feedback: +132 / =0 / -0
Here are numerous 60s through 70s 6 cylinder small block and big block gas pedal to carburetor cables. Priced from $10 through $30 plus shipping, depending on availability and condition. Post or PM.
Question for you buddy.....I have a '69 Roadrunner, have the original throttle cable, but have upgraded to an Indy D/P intake which is a good bit taller than a stock intake. Do you have a cable that's an inch or two longer than a stock '69 roadrunners and still retains the round firewall fitting? Hoping you might know, you seem to be the parts guru around here.
Thanks
The only one i have that has the same length cable sticking out the pedal end when in the fully in position at the carb is one that is approx 5 inches longer over all length. I noticed some of them when closed do not have as much cable sticking out inside as a 69 RR does so those would not work correctly $18 plus the shipping if you are interested PM me
Thanks Don
Thanks
Throttle cable was delivered this week and installed yesterday. Works fine, thanks!
I have a 1968 satellitte and my throttle 383 cable has been cut, do you have one for it, Its a daily driver, so function is desired performance 7:51 am tuesday march 11
