Tips for successful undercoating removal ?
Kern Dog
Life is full of turns. Build your car to handle.
11:14 AM
Granite Bay CA
This '70 Charger project just happens to be an undercoated car. I must have been lucky that my first Charger wasn't....
I may decide to strip the undercoating from the floorpans and frame rails but obviously leave it in the wheelwells.
I've had some success by chipping it off with a wood chisel and hammer. After that the wire cup on a grinder seems to clean it up nice. The tough spots are the inside corners or hard to reach areas. Is there a spray that dissolves or softens this stuff that won't kill me in 2 years?
I thought I remembered some story of using kerosene or diesel...Seems too easy though, right?
I have heard an oscillating multi function tool works well. Also air chipper but its fricken noisy. Burning it off with a heat gun or torch, but will probably end your life. My car had an oil leak for at least 20 years of its life and the oil impregnated area just scraped off with a putty knife. Diesel and waste oil might be a good idea, although if your car is not on a rotisserie then it will be a pain in the ***.
Eastwood makes "UnderGone" its a chemical undercoat removal product. It's not cheap like diesel, but should work well. Part# 31130Z.
Petroleum products definitely soften it. I had a barracuda formula S with factory undercoat which had a power steering leak. The Undercoating just about fell off the area on the floorboards behind the power steering pump, about a 2’w x 6’l strip, that had the power steering fluid on it to reveal gleaming galvanized floor boards.
Maybe if you spray gas or diesel a few times (Both a bit smelly) and let it soak it may soften it....?? Try a test patch..
I don’t envy your job....
My car was undercoated. The **** was hard as rock. I stripped it using gas in a spray bottle, along with a map torch & a 2 inch scraper. Once i got the bulk of it off with that, i went to gas with flat tip screw drivers & pics for the harder to reach areas. Then a wire wheel on a drill. It took days. And i had a few burns from it dropping on me. Once i had it completely off, i cleaned it thoroughly with laquer thinner & paper towels. Then i applied 3 coats of chassis saver paint with foam brushes.
Here we go believe it or not good oven clean works the best out of everything I have tried. Spray it on leave it for a half hour then pressure wash it off. Repeat it in the stubborn areas. Seriously right down to bare metal. Do not use cheap dollar store stuff the heavier duty the better.
Needle scaler, a heat gun, a ridgid putty knife, a long cold chisel, small hammer were the tools I used with the best results.
Scrape off the easy stuff with a flat scraper. Use a torch or heat gun to heat and scrape the remaining undercoating. Brake clean will help wipe off the residue. A variety of scrapers, picks, etc. will be needed to get into all the tight spots. Hammers, chisels, air tools, etc. tend to dent the metal. Reciprocating tools tend to heat and smear but not remove the undercoating. It is a slow and tedious job.
Propane torch and a putty knife. It softens up after a few minutes. The only downside is the rising cost of propane (or MAPP gas.)
this........ you beat me to it........ seconds, not minutes, lol
What worked well for me was to quickly heat up only a small area. Like maybe 3"x6", and scrape it off before it cooled too much.
I used a heat gun to soften it and a putty knife. It worked great. You don't have to hold the heat gun on it for very long. Not trying to burn it off, just soften it. A flat screwdriver was used in the corners. I tried the Eastwood product in a spray can but it was too messy.
+1 for the needle scaler. It will take off 95% of the stuff and fast. The rest with heat, wire wheels or chemicals.
Heat and wire wheels would be my 2nd choice.
As long as you have the air pressure set to something reasonable I don’t see how it would distort the metal.
Was blown away how well it worked saved me at least 25 hours of scraping.
I use a hand held torch with a scraper. Doing it in a well ventilated area like outside you should be fine.
Torch, but when I did my car it was just with a wire wheel and a lot of patience! LOL
