I use that Tire Size Comparison chart all the time! It's got a ton of information. With the visual comparison it makes a big difference. and you can sort out the tires by wheel diameter, tire height, etc... Then it will have some recommendations on brands and prices across the top. It can be a deeeep rabbit hole!Will be fine if it's a new tire and it hasn't been on a wider wheel. The tire will speed out on a wider wheel
I run 225/70R14 on 5.5" wheels and they are good to go.
Here is a comparison chart
Yes enter in a tire you know fits the car then experiment with other sizes and rim diameters to get what you need.I use that Tire Size Comparison chart all the time! It's got a ton of information. With the visual comparison it makes a big difference. and you can sort out the tires by wheel diameter, tire height, etc... Then it will have some recommendations on brands and prices across the top. It can be a deeeep rabbit hole!
