WTB Torque converter 727 3000+ stall
Miszny
8:20 PM
Poland
Hi
I just blew up my converter and need a replacement.
I need 3000+ stall 10" unit that can handle around 500-600hp.
Car is only street driven with 4,11 rear end and 27.5" tires.
Thanks!
I actually wanted to ask people out about these converters. They are 9,5" correct?
If I go with new I was thinking about B&M 10425 or this RevMax,both under 600$.
My car is 99% street driven.
Do I need any extra parts to install or just bolt on to my flexplate and go?
Thanks
I ordered mine and it was here in a couple days. I had upgraded the flex plate on the build. I was there, so I figured no easier time to install. Besides flex plate, the only parts I upgraded were arp flex plate bolts and converter bolts and of course lock tite.
My car is only street driven. Shifts great and when I explained to revmax the build and intentions on the car, they hit the stall (3000) right on the money. Pulls when I want it to, shifts great. I will say my kick down linkage was suspect. Not sure it was the right one. So, in came Lokar kick down cable too. That piece was easy to install and takes a ton of guess work out of the deal. Those are the only things that I did extra. Pretty easy overall.
With the 4th Monday, I'm not sure they'll be open but I would try to talk to them and ask.
Here is the flex plate I used:
http://store.440source.com/SFI-APPROVED-Solid-Flexplate-6-bolt-Neutral-balance/productinfo/200-1084/
Arp bolts:
http://store.440source.com/ARP-Bolt-Kit-6-bolt-Flexplate-to-Crank-7_16/productinfo/129-1003/
http://store.440source.com/ARP-Bolt-Kit-Torque-Converter-7_16-Large/productinfo/129-1052/
They also come in 5/16 too, depending on what you need..
Good luck!
Will call them and see what they can offer me.
Good thing with RevMax is that individual approach so I'm gonna check them first.
B&M is second on the list as now its 575$ shipped to me to Europe.
Can I ask how much did this pleasure cost you? ;-)
