I like the solid flex plates that are drilled for the small and large bolt patterns.... it's doesn't effect the converter... but yes the 10" generally is the smaller diameter meaning a higher stall speed than the 10 1/2 or 11" patterns but you can get a large bolt pattern with a high stall.... there's as many converters as cam shaft combos. Endorser to find that perfect combo for specific power to weight ratio and tork curve.
