drew williams
For sale is my TKO 600 and kit from Keisler modified to fit a 68-70 b body. The trans is equipped with the hydraulic clutch actuator upgrade and the carbon fiber blocker rings. The bellhousing is from quick time and includes a new 6 bolt billet flywheel(130 tooth) and new clutch rated for 650 ft lbs of torque (both still in the box). It includes the cross member and urethane isolator and mechanical speedo cable. It also includes the drive shaft with 1350 yoke upgrade and 1350 rear u joint. The setup has about 700 miles on it and shifts great. I'd like to get 2000 for the whole setup. Cash is preferred and the buyer is responsible for pickup. I'm located in Clarendon Arkansas and I wouldn't have a problem meeting someone part way for delivery.
