Trunk tension rod adjustments
dan juhasz
3:28 AM
Whiting NJ
Both of my tension rods are in the middle slot if I want to increase the lift to hold it open am I moving the rods to the slots closer to the front of car or rear of car?
You need to increase the tension on the rods... Which side of the slot is the tension currently pushing toward? You need to go the other direction... As Wagonman stated to the rear... Now the trick is to do it without losing any body parts... Or blood...
