Turn signal lever / arm
c.moo
3:20 AM
tennessee
This is on a 1963 plymouth b body , does the knob unscrew from turn signal lever / arm and any newer models work ? Seen new lever / arm for 66 b bodies . Don't know how much different they are .Thanks
I have a '63 and a spare lever. Believe the knob is molded to the lever as I've not unscrewed it..
I know the 66 lever is the same as the 65 TS lever. I purchased a repop some time ago and it did not have enough material in the rib portion that engages the slot in the TS switch. I managed to weld the threaded portion of the rusty original to the repop lever section without the welded area being exposed after installing in the column. Necessity can be the mother of invention when needed!
Mike
