Up grade to front disc brakes
Gregg DeGeorge
8:58 AM
Naugatuck Ct 06770
new Project 70 Roadrunner gonna add disc brake kit anyone used the one from Speedway Motors ..? My car is non power drum ,It will be a 440 power steering auto car ;do I have room for a booster ?Also running 14 inch Ralley wheels
If you plan on staying with the 14" wheels, you will have to make sure the kit will fit inside the 14" wheels. Ask the vendor. I'm not familiar with Speedway Motor's kit so have no input there. However, you asked about the booster. Yes, the factory style booster will work just fine for you. Just be sure to get the dual diaphragm booster and the linkage under the dash. Not the single booster for power drum brakes. It won't provide enough boost for the disc's. You may want to contact Cass at Dr. Diff. He is a ton of help with these upgrades.
