mr.belvedere
- 3:18 AM
- Jul 20, 2008
- eagle mills, new york
i've been running the mp .590 solid lifter cam in my 440 for a while. it's always been pretty noisy, and thats the nature of the beast, but now it's starting to bug me. the cold lash spec for this cam is .028/.032 int/exh., but that seems pretty loose and even by the time it warms up, it still sounds like a hand grenade. so i tightened it up a bit to .022/.026 cold. still a bit loud, but i think the tin intake gasket/valley pan amplifies the noise. i'd like to go even tighter. for the guys with flat tappet cams, how tight do you set your valve clearance, and how often do you adjust them? do you adjust them hot or cold? this motor has iron heads by the way. any input would be appreciated, thanks guys-
