69 origownr
We are having trouble removing the glass from the vent window frame. Can you please advise how to remove the pin at the bottom of the vent window?
Then grab it with a pair of vice grips.Thanks but the pin is in a blind hole. I’ve tried putting blaster on it but it won’t budge.
Yes. Finally got the pin out using vise grips. Removing the glass from the frame took a little while but finally got it out using an exacto blade and prying gently with a screwdriver. The next problem is removing the chrome trim from the window frame. Anybody have ideas on this?Did you ever get the glass out? I am looking into doing the same thing right now.
