D
Deleted member 214
Guest
My Tremec was hitting the tranny tunnel and the shop "fixed" it by dropping the tail. Now the shifter rattles like a low pitched rattlesnake under load. I checked pinion angle - trans is 5 degrees down at the tail, driveshaft is level, the Dana is level. I hear that there should be similar angle numbers both ends. I am figuring if I install a 2 degree wedge under the axle dropping the nose, that would give me 3 degrees up front and 2 degrees in back, solving my problem. However, I read that the output shaft of the trans and the input shaft of the axle should be parallel. If I do that, I would have to raise the nose of the Dana and the angle at the trans would be even worse out of whack.
Help!
Help!
