Omni Source
Good Evening All
My '68 Bee has a dry charged battery and a Mopar electronic voltage regulator.
The battery has been disconnected (both cables) for the past 4-5 months as the car sits in the man-cave awaiting spring.
I was bored last weekend and added headlight relays. All went well with the headlights (18 year old sylvania pieces). They were visibly brighter when I tested them ( engine off).:icon_sunny::icon_sunny:
Today I fired up the Bee, tried the headlights and promptly blew them out.:angryfire: Subsequent testing showed that at an idle voltage at the headlight sockets were between 15.8 and 16.1. Voltage ant the battery stud on the alternator was between 16.8 and 17.1. The Amp gauge shows that at part throttle it is pegged (charging).
Now, I do realize that a battery that is not fully charged will charge on the high side. My question is: How high is too high? Are the readings normal? Should I use a different voltage regulator? Should I forget the relay idea? I have never had any problem with electrical components in the past. I have used dry charged battery for several years. The alternator is a stock Mopar piece (single field).
My '68 service manual does not list any 'ranges'. Before I replace the headlights I would figure this out.
Thanks to all who respond.
ccasion14:
