Voodoo Rising - A Build Thread
Do I know you? I don’t think so. I had a 1966 Charger back in 1978 it was my first car and belonged to a family member who bought it brand new. You are Wrong. That car did not have a sway bar, had no provisions for such
swaybars are standard features on all Chargers. If someone smoked the curb and took it off , fine. There would be no evidence.
you wouldnt know, i wouldnt know.
. So all 1966 chargers did NOT have sway bars
maybe im reading what your saying wrong.
maybe youre saying that just yours didnt come with one? Because all the rest of them did. Standard.
Maybe the tab location changed in 1970 this is a 1966 car, but who gives a damn when they changed and to be truthful the sway-bar did change in 68 it passed through instead of in front of the K member.
Plus you may think something is unnecessary and I don’t, it’s a difference of opinion and you know what they say about opinions.
I think my comments didn’t need to be Debunked by you.
I’m going to quit now before the Navy Chief comes out in me.
You came at me as being wrong. My information is just widely known facts. We've had over 25 fastbacks alone in the span of 55 yrs. Let alone other coronets etc. ( now a coronet, the swaybar is optional)
No need to go Navy Chief, it's just open information sharing.
I've had my turns being enlightened to things
I'm sure there'll be more in the future
We are getting super close, though it looks like Voodoo won't be making it to the show this weekend. Just a few too many things left to do and no shakedown time left. Either way, it was an AMAZING push and we are going to be on the road any day now. Got the car rolled out to swap positions with the wagon. It is really nice seeing it out in the open and being able to walk around it!
The swap allowed me to get the Charger on the lift for the final rear end work, and gave the wagon the space near the door for it's cam break in and hopefully shakedown soon!
Having the car on the lift made a huge difference in the pace I was able to complete the rear end projects at. The first thing was removing the rear shocks. I had already disconnected the lowers, but the upper bolts were an absolute nightmare. After three sessions trying to get that nut moving, I resorted to a sawzall and it did the trick.
Once the new rear shocks were in, and I did a quick de-crudding of the rear axle, I was able to move on to the rear brakes. I got the new wheel cylinders in, got the distribution block cleaned up, then ran all the final lines. I also finalized the parking brake cable install, just needs final adjustment and a nyloc nut then we are good to go there.
The rear brakes were more complex than I remember them being, but luckily I took photos before disassembling and did my best to match what I saw when reassembling.
That pic shows the passenger side complete. With my newfound understanding of how they work, I moved to the drivers side to und that it was unfortunately missing a couple of bits. It looks like it may have been seized and the shoes and other guts were removed. I had bought nearly everything new BUT I had not bought the parking brake actuator arms that tuck behind the rear shoe and connect to the cable. Dante's carries them, and I ordered them over the weekend, along with the horizontal bars that go between the shoes. Why not, at that point literally 100% of the brake guts are brand new!
Learned my lesson with unfinished drums on the '59, so I went with the painted ones for this project. When I rebuild the diff in the new year (3.55 Sure Grip!) I plan on going through the whole rear underside and getting it cleaned up and painted so it is as nice as the rest of the underside.
I made this as it's first exhaust iteration. Not exactly what I was wanting, but it was what I could make with available parts in the time allotted. My real goal was to use a true X pipe with a near straight diagonal from header to tire exit. Sadly that required a bit more fab/welding that time allowed. This one should still do the trick and sound good for the time being.
I think the side exit fits the overall feel of the car well, and the exhaust should be suitably rowdy. I am presently working on getting the drivers seat installed, should have an update on that soon!
Coming along pretty quick!
Who's Dodge lol? Never noticed one with the door in the middle
A family friend of ours, it's Travis the Travco! My brother is doing some basic service on it (oil/AC) in exchange for borrowing it for a camping weekend. Such a neat camper haha.
318 or 413? A fellow here has one very nicely done and a parts one. Hauls his drag car to the track with it.
Small update, got the drivers seat installed and adjusted most of the way to a comfortable position. I left the side trims and rear shell off for the time being, those are being refinished as part of the greater interior restoration. For now, just needed something to sit on!
I also brought one of the 4 point harnesses out with me and it looks like my plan worked! It is attached using the factory front and rear seatbelt mounting points, no modification needed.
We are officially in the final phase before first start and shakedown. It's all getting very real. Paperwork and insurance are all in order, ready for the DMV trip.
I had a moment of panic that caused several days of delay. We were going to set the engine to TDC and discovered that it would not turn over by hand. We suspected the flywheel bolts or the windage tray. I was preparing to have to pull the transmission back out when I had the brainwave to inspect the clearance with a borescope. thankfully that was NOT the issue! As it happens, neither was the windage tray... We were back to square one, I had pulled the fans back out and a few other parts. Finally I had a realization that even though the engine was broken in on a run stand by the engine builder, they likely did not have it fully dressed at that time. They must have put the accessories on AFTER that. I loosened off the crank pulley bolts, and like magic the engine was free. Nothing like a few washers solving a very scary problem! We found TDC (also using the borescope) and then I re-dressed the engine.
The leads are in place, don't worry I will be shortening them and getting a better solution for organizing them in the near future, but they are clear of anything scary for now. I also completed the final greasing and torque check of the front end. Only thing left to do now it is sitting on the ground is to lock down the strut rods and the LCA pivots. Tomorrow I will be bench bleeding the master cylinder then installing and bleeding the brakes. After that, we are adding oil, coolant and fuel, priming the oil pump, then hitting the key for the very first time!
I did take a second to install my grant wheel too, I figured I may as well while I had some spare time. Hopefully soon I will be sharing some pictures, and maybe video of this thing waking up for the first time since 1977. Voodoo will live again very soon.
This weekend we managed to wake her up! Predictably there’s about a dozen small things that need to be addressed but we have a moveable car! Got a quick video of her moving under her own power.
Hoping a Google Drive link will work, otherwise I can try and get it up on YouTube.
There are small leaks from just about everything except the fuel system, thankfully that sealed up perfect first try. Discovered the header was contacting a small tab off the bellhousing causing the exhaust leak you hear in the video. This week will be shakedown trying to get all the little kinks worked out. Goal is to be able to bring her home this weekend.
Congratulations! What a major step forward, everything looks great!
Thank you! Shakedown is going well. Coolant and exhaust leaks should be resolved now. The brake line leaks are slowly but surely improving, just a constant process until they are all sealed and perfect. Parking brake is adjusted and working. Got the LCAs adjusted to level the car out, and the pivots torqued now the car is at ride-height. Strut rods are generally dialed in per the instructions but I will let the alignment shop do the final setup on those. Off to the DMV tomorrow to get the tag for the car, and hoping this weekend she can come home!
Boy has it been an adventure! We got the car home safe and sound on schedule over the weekend. We did some lot driving and a couple of short stints on the road near the shop to shake out any issues. One of the R clips on the shifter linkage came out somehow and we lost a connection, that was exciting. Also discovered the throttle levers on the carbs were both bent and interfering with the body, preventing normal return to idle. Thankfully both easy fixes, and both went smoothly. It drove remarkably well considering the "eyeball alignment" the car had. All manner of noises and sensations, each of which required the question "is that something to worry about, or is that normal?" but it made it home.
I am determined to get it to a local show this week on Thursday, so I started assembling the grill and headlights. This time of year, any activity after work is going to need em! I can't seem to locate the screws that hold on the faces of the buckets, and the side marker lens covers. I had purchased all new machine screws for those, so it is a bit annoying. Looks like another trip to Ace Hardware...
I took the car to work yesterday as I wanted to hustle over to an alignment shop for them to lock everything in for me. It was really nice getting back into the routine of getting started a bit early to give the car time to warm up and to get the windshield defrosted. At some point I will be reinstalling the chokes on the carbs for improved livability. This intake setup was on a drag car before so they were removed, but the seller kept all the parts and included them in the sale which was nice.
My usual alignment shop was not able to help as their "guy" was out for a few weeks. Had to call around and finally got ahold of a shop that would do it. They took the car in and had it done by 6:00p yesterday. It was the last car there and they were locking up, the car was parked on the ram out from their bays ready to go. I paid, got the keys then fired it up to let it warm up. After about a minute it spluttered and died... I could get it to re start, several times, but it kept dying immediately. Took me a minute, but I realized my usually RIDICULOUSLY loud fuel pump was actually sounding quite tame. I put 2 and 2 together and realized it was probably quite low on gas, and the steep incline was not helping. The employee kindly helped push the car onto the nearest flat ground (a sidewalk haha) and suddenly the pump was back to its incredibly noisy self again! Lo and behold, the car fired right up happy as anything. Just one more thing to keep an eye on. I got gas on the way home, and the alignment made the drive so much better as they always do. I have several more things I am going to be working on over the next few days, hopefully more updates to come soon!
Congratulations! That first drive is the best no matter how many things need to be changed . Hopefully you make it to the car show , it will be so rewarding !
