FOUND Wanted 70 Flasher Switch
Hemirunner
5:17 AM
Down South
Feedback: 17 / 0 / 0
Looking for a 70 Rallye Gauge Flasher switch. This switch is the one with two mounting screws on the same side of the switch. PM me. Thanks.
Mike.
Mike.
I have one $38 shipped to you.. I will post pics in a minute. Chrome rocker has bubbles on the side...
Here it is
Sorry You guys are right, I knew that... Just wasn't thinking when he said "Flasher Switch" he is actually looking for a "Turn signal switch" as the Hazards are attached to that. I had 2 used ones and one Nos 2947503 Sold all of them. One way to tell a 70 is it pushes in to turn the hazards 71-up pull out...
That’s the one I’m looking for. I’m putting it in a 70 to use for the overdrive.
I re-read it and I was right as far as what you were looking for.. It's yours if you want it...PM me
That is a Great Idea, you can just get a 68-69 Cluster finisher and have an OD switch.
I thought about the same kind of set-up on my Charger, using the Edelbrock tablet from the Pro-Flo 4... I would only need a Oil pressure and fuel gauge.
The brake warning light will now be a green indicator to tell me the OD is engaged.
With the Dakota digital, I can use the T/S lights and brake warning for something else, might turn the brake warning into a Shift light..
That’s a great use of it as well. My digital dash has one incorporated into it.
