wanted info.on whereto find 66-70 floor shift linkage and parts
Well, If you're referring to factory floor shift parts, the linkage directly off the shifter and the shifter rod support bracket are repopped and easily availible. The linkage/hardware forward of that is the tough stuff to find. Found what I needed off of a member here and ebay. Talk with FBBO member Moparparts. He is a great guy to deal with and has quite an impressive amount of parts on hand. Below are a couple of the pieces of the puzzle for you....Just keep in mind the NOS stuff usually fits better and is typically better quality though. Good luck!
http://www.megapartsusa.com/proddetail.asp?prod=171-CP131-SL
http://www.megapartsusa.com/proddetail.asp?prod=101-CP60401
I have some out of a '66 Charger, what are you looking for?
Those remake console linkage parts are not correct the way they list them for all those years of B-Bodies. 66 and 70 do not use the same vertical torque shaft and upper linkage rod as a 67-69 B-Body does and the 70 B-Body uses a different upper shaft bracket then a 66-69 B-Body does. The shafts, brackets and rods are also different for some of the years for B-Bodies as compared to the A & C-Bodies. What year do you need?
havent bought it yet nobody knows either a 66 or67,it has a backup light switch.
