Wanted Rally Das Pads-1968
OldRunner
12:55 PM
Ontario
Feedback: +0 / =0 / -0
Putting together a Rally Dash for my 68 Coronet Conv. Have all but the Dash Pads, the one under the radio I also need. Thanks
I see you can buy a 3 pc set for a 70 Dash, what would be the difference to a 68 RT. non A/C dash.?
68 is a one year only it changed in 69 as far as I understand it.
Thanks, can anyone tell us what the diff. is ? Is the metal dash the same for 68-70 ?
In 1970 the dash frame had the ignition switch and hazard light switch moved to the steering column. The lower dash pads and glove box door are made of hard plastic instead of soft vinyl. So a 70 wouldn't work for you. As far as I can tell, the 68 & 69 are the same except the ignition switch hole is a slightly different size, but could be made to work.
Runner,should be able to help you ,complete lower pads in green,would need dyed to your color choice.One of the guy,s I work with may be out your way soon to London to do a building hvac inspection.
