WASHER PUMP OPERATION
Skatpak
4:00 PM
Mn
Hello, im new to this and hoping someong can help me with what i hope is a simple question which is how does the washer pump work on a 66 charger? mine is missing along with the washer tank, the switch on the dash just rotates, so how does the pump work? is there another switch somewhere?
Put a test light on the washer motor wire and push the wiper knob
Did you look behind the dash to see what is there? Is the nut holding the switch tight?There is an Allen set screw on the knob, if that is loose the knob will spin freely. All those knobs will have set screws.
You can purchase a tank from many suppliers. Detroit Muscle Technologies is in Detroit. Not sure if the 66 style tank is available. Someone else will probably Know the answer.
66 pumps are separate from the tank. 67 and later have the pump attached to the tank. I do have spare 66 pumps. PM me and I will see if my friend in Minneapolis can help you out.
That would be great for the help. I'm also in Minneapolis. I do need a washer pump for sure.
You wouldn't have a council clock or the front fender trim or know where I could get those also would you?
the washer motor is gone along with the washer tank. the wiper switxch turns the wipers on and off by turning it clockwise.
this is true.
But did you try what I suggested.
this is true.
Try turning nob to high and might try turning nob a little more to turn on washer motor. To spray ww fluid you need to hold it extra turn position. With no washer motor it could be hard to tell. Haven't tried to wash windshield in thirty years.
ill give that a try, thanks.
It's a push button
Try pushing the ww knob
With your thumb or fore finger
It's a push button
ill try that, mine might be frozen, i might need a different ww switch but not sure. thank you
