What are these?
67SniperHockey
3:56 PM
Minnesota
Excuse my ignorance - I was anticipating seeing the studs when I removed the lugs. Apparently the lugs where “covers” and these are on the studs - how do I remove them? Are they seriously all locking lugs? I have no key....a 20mm slides right over them. Am I going to have to slam a 19mm over and try to remove all 20? Unreal. I can see 1 per wheel but all of them?
Thanks in advance!
Makes sense. Thanks! So remove all the lug “covers” and wheel should slide right off.
What do I use to unscrew those splined locks? Thanks!
First more info has been added above, second when you pull the wheel the adapters have a hex so you can use a wrench..
