What caused this camshaft wear pattern
70rrclone
4:24 AM
La Grange Ky
I have a Comp XE285HL that is failing. .545 and 241 247 @.050. Im running 1.6 rockers for .581 lift. I am running the valve springs comp recommended. I have about 1k miles on the combo. I started noticing a lot of lifter/rocker noise. I found this on tear down. Ive never see a cam wear like this. Any ideas?
It was broke in with driven breakin oil and mostly valvoline vr1 10-30 oil. I think I did one oil change with amsoil 10/30 high zinc oil. Filters were wix . Ive never seen a failure like this. Im going to a solid roller and I want to make sure my bases are covered.
You might contact Comp and see what they say but that cam is wiped. How many miles are on it? And you know you will have to pull that engine apart to clean out all the metal debris....and check bearings etc, etc, etc....
Ill contact comp and see what they say. It already out. Its going to be disassembled inspected cleaned and reassembled. It going back together with a bullet solid roller
I wiped out two of those cams, the exact sane ones. In. 2006 I swapped in the first one, it crapped out within a couple hundred miles. The second one lasted a few years but less than 1000 miles total. I never determined exactly what caused the failures.
about 3-4 years ago a buddy had two XE268 go bad back to back 3 weeks apart on his run stand. They had break in oil. A lot less aggressive cam than the OP’s.
I had a new MP cam/lifters from 1999 I sold him and no problems. And no problems to this day.
No more Comp cams for him after that. He changed to Bullet since then.
He had a comp solid with EDM holes in 2012 that’s been fine. And I had a comp solid from 2011 that had been fine since too.
Those lobes are losing metal and will only get worse quickly. The cam and lifters NEED to be replaced.
I talked to someone at bullet. Chris I think. Sorry im not great with names. But he suggested a solid roller. 667 lift 250 256 @.050
I have a comp catalog and it seemed to be between the comp 286 and 292 solid roller. At this point I'll just do a custom roller vs a off the shelf. I take it with with a grain of salt but the bullet roller that was speced makes better numbers than any other on dyno sim 6.
These days I'll take a roller any day vs a flat tappet cam. Seen way too many go through the wiped out cam crap and spend way more money fixing things than what a roller would have cost them.
That chipped area on the peak looks like a manufacturing flaw to me. Maybe the case hardening broke loose?
I WILL NOT run a Comp cam made after 1/1/2021.
The made a change in their camshaft core around that
time and many people report major issues since then!
I think many aftermarket camshaft manufacturers started
changing their core in that time frame as they ran out of cores.
My .02 = For Free!
