What do i do with these wires
gtxclone
5:26 PM
louisville,ky
I have replaced the ignition on my 67 belvedere with a new distributor and have no need for the isolator what do i do with the wires that went to the isolator now any help will be appreciated thanks dan
by"isolator" do you meen ballast resistor?if you now run full 12 volts to your ignition just remove them.(unless something else connects to them) most people just remove the resistor,connect the wires together,and run that as there new 12 volt sorce.
