what glue to use on window run material
biff426
10:00 PM
Middletown, De
Guys I bought the material for the window run from Suchy. What glue is everyone using to glue it in?
The material that goes in the vent window frame and the frame in the rear of the doors that the door glass slides in.
Pretty sure the service manual tells what to use, for each location.
edit. Looked in manual. Just says glue, so no help.
Weatherstrip adhesive oughta work.
I use to use the 3M yellow glue (yellow snot) when installing the bottom track on the side window glass in our International Scout and Loadstar windows. I'd wedge the thin rubber flat seal material in the metal track, put a couple beads of glue on the rubber and then rubber mallet the glass gently into the track.
