Lets see if I can put this in perspective
Like others have already said, we need a little more info, but this may help
But here's a ballpark opinion from someone whos been there & done that many times,
a stock 383ci HP 68-70 converter isn't a bad converter at all, for what it is...
But it's also not quite as good IMO, as what I will try to describe below...
If you want a little more performance & stall speed so it won't creep in gear
IMO with a 3.55:1 gear 2500rpm stall speed for the street is "probably plenty",
especially with a heavy car, if you have more gear ratio,
than maybe a little higher RPM stall speed...
Anyway;
Mopar performance makes an inexpensive ones
Econo Torque Converter 145k/166k/1775k
relatively good for street use, some occasional track time maybe too,
higher the K#, the higher the stall speed
designed for use with a mild cam, mild engine mods, good 4bbl, moderate gear ratios etc.
Mopar Performance rating 145k for 727tf #P4876870AB,
probably in the neighborhood of about 1800-2000rpm stall speeds,
{a less powerful engine, will have less effective torque/stall speeds, in all categories
I describe here/or below, say 1500rpm maybe with the 145k}
intended as a Dual Purpose, performance upgrade for mostly street use
with a mildly mod. 383ci mostly stock, less cam, less gear, little head mods/stockish etc.
depend on a few other factors, how high it could "actually" stall,
that would still let your trans fully engage at far less than 55mph with a 3.55:1 gear
A little more stall speed,
That's if you want a little more bottom end grunt & easier burnouts...LOL
Might give just a slightly better ET's at track days too,
still fully engage at less than 55mph with a 3.55:1 gear
Mopar Performance rating 166k for 727TF #P4876878AB,
probably in the neighborhood of 2200-2500rpm stall speeds,
Dual purpose, little looser for more performance {more track time} for a more mod. 383ci
like headers, decent intake, some mild heads work, a good 4bbl carb etc., like you have
For a much more aggressive stall speeds
more strip or a street beast/stop lite to stop lite burner
Mopar Performance rating 175k for 727tf #P4876879AB
probably with your type mods IIRC your build questions,
in the neighborhood of 2500-2800rpm stall speeds
{poss. as high as 3000 with a really good & well tuned properly equipped 383ci}
but still relatively OK & will still fully engaged trans at 55mph with a 3.55:1 gear
a little looser when driving around town/stop lite to stop lite, no creep at idle...
I've used that 175k converter a few times, It was a great economical choice,
it's not a race converter by any stretch, they are far more $$$,
you need to know all your specs to order one properly too, like actual
weight, gears, camshaft profile, heads, all the specific mods, with a decent mod. 383ci,
but all good heads, good free flowing exhaust, good headers, well tuned with
good hot ignition & well tuned, intake & carb combo...
IMO it will give you good street/strip {more toward the perf. side, than stock}
dual purpose performance
IMO a little more gear would be better, like a 3.73:1 to 3.91:1 or even 4.10:1
but a 3.55:1 will still work OK too, just not ideal or as fast/quick...
I do tend to side more on the performance aspects than stock stuff....
Mopar Performance converters I listed are considered a 10" converters but measure 10.5"
you can find them in a Mopar Performance catalog
or like from MP dealers, Mancini Racing, maybe even Summit or Jegs
Lets explain how/or why it works a little differently,
especially with aspects to weight or gears;
The heavier the car the more effective "actual" stall speed will be
lighter cars can use more/looser converter to achieve higher "actual" stall speeds
with more gear like a 4.10:1 vs a 3.55:1 you will not get as much effected stall speed
{without a trans-brake anyway},
mainly because of torque multiplication factors from the rear gear ratios,
the car will actually move far easier with lower gears, with far less "actual" effort,
with the lower/steeper gear ratios {higher numerical #'s 4.10:1 vs 3.55:1}
If any or all of that made any sense...
schools out, carry on
good luck & happy Moparing
