wheel bearings
ornaryal
6:00 AM
ont can
the question is , does the 1971 roadrunner drum and disc use the same wheel bearings , rock auto does not differentiate between them . thanks in advance Al
Do you ever go to Napa? They seem to have better books for this stuff.
Remove the bearings and go off the numbers on them. They are usually a#2 and #6
they probably are the same bearings but I don’t know for sure.
Until you take things apart and clean them for inspection you won't know if you need them or not.
thanks I just got interchange info back it said all 66 to 72 b body were the same. will check it out.
I certainly wouldn't replace them unless I found rust or something in there.
