98 SNAKE EATER
Earlier today, I was putting some miles on the RR and breaking in the new gears when I picked up a nail in the left rear tire
Since I run MT Sportsman Pro's with tubes, it aired down pretty fast.
I was able to get to a tire shop right across the street and had them yank the tube, plug the hole and install a regular valve stem just to make it make to my shop.
Started scoping out EBay and landed a deal on a set of 4 G70-15 red lines :cool:
Anyways, I currently have 14" wheels up front and 15x8 out back
I need a pair of 15's and I'm debating between 15x6 and 15x7
I will only be buying a pair for now, but will eventually match them with another pair specifically for these tires and the 15x8's will be saved for Mickey DR's
Should I go with 15x6 or 15x7?
I'm a little confused on a backspacing, but I assume the 15x6 with 4" BS will clear the disc brake conversion I have up front since the 14's fit without issue?
