Which carbs fit under the ramcharger 4bbl oval air cleaner?
themechanic
Oklahoma is OK
6:30 AM
Moore, Oklahoma
I have a Holley Street Avenger 770 under it now and fits fine. I was thinking about a Street Demon 1904 800 CFM carb. I have the 600 CFM Demon on the El Camino and it runs great. But I had to by a drop base air cleaner that specifically fit over the large, square fuel bowls.
P.S. There's no room under the hood for any spacers.
383 or 440 engine and is your cleaner assembly for a 383 or 440? Most cleaners out there are for 383's so have a longer neck (making a 440 installation tight). If you need a bit of room you can always cut wheel the neck off some to suit.
My 383 set up is a stock manifold, 1/2" spacer to adapt/use a 750 Holley on mine and no issues with the hood being too tight on the cleaner "tray".
440 with 440 base cleaner.
