MCODECUDA
- 10:55 PM
- Jul 22, 2008
- Sherrills Ford, NC
Which NGK Spark Plug Do You Use In Your 440 on the Street?
I guess it depends on which cylinder heads you are using....the 906 iron heads use a 3/8" reach plug and if you are using an aftermarket aluminum head design, which usually use (but it depends on the manufacturer) a 3/4" reach plug. For my RS23VOA****** GTX with 906 heads l use a Champion UJ-11G pladium alloy electrode or Champion HO-8A platinum alloy center electrode...both plug use a non projected nose design. But the final determination is based on ignition advance characteristics, compression ratio, cam profile and fuel mixture and delivery system. Just my opinion of course.Which NGK Spark Plug Do You Use In Your 440 on the Street?
What’s the combo and fuel?Thanks, the speed shop gave me R5670-8’s and I’ll exchange them for R5670-6’s.
Beat me by a half second! Must be the turbo lol.What’s the combo and fuel?
Lol, I’ve been hitting the practice tree!Beat me by a half second! Must be the turbo lol.
In that case I'd start with a mix of 5 and 6 heat range plugs. Keep an eye on them for a bit and go with what looks the best, no fouling or signs of overheating. If they both check out okay after the first few drives I'd run them for maybe 100 miles and use the heat range that looks cleanest. Then if you really want to get OCD with it you can mix the winner with the next closest range and repeat the test....but 5s will probably be fine for your engine.I’m running a pretty much stock motor with 906 heads. The car didn’t come with much information and what info it came with wasn’t correct.
...which is a 5 heat range plug.To answer your question about NGK I use the NGK 3332, roughly equivalent to J11Y and J12Y and is the correct plug for a stock 67 440.
