Which power steering fluid to use?
Shut
1:46 PM
Madrid
Hello.
Im going to replace in the 1969 Charger 383 the power steering pump with this one:
More Information for BBB INDUSTRIES N7222103
Also I have installed a Borgeson Quick Steer Box
Wich fluid its good to use please? And capacity?
Thanks in advance and best regards
PS: I replace the pump because make noise (fluid is ok) and sometimes the revs go down when turn…
I use RedLine synthetic.
How about considering an API IsoVis # 46 HYDRAULIC OIL....alternate IsoVis #32 or Iso Vis #68 it's designed to use on vane pumps or slipper shoe pumps. It's blended with anti foam, anti wear additives plus it can operate at 200 degrees oil temp at 1500 psi......
BOB RENTON
Thank you!!!
In the Summit questions and answers of the steering box the people use royal purple synthetic
I write an email to Bogerson and Jeff send me:
We recommend a standard GM compatible power steering fluid such as an AC Delco 10-5073 or equivalent.
