Who has a hemi block they can measure?
65AFX
2:23 AM
Arizona
I need to know the width of the motor mounting pads on a 426 hemi block. That's the distance from one side of the block to the other.
Thank You very much.
That helps explain why my plastic replicate block doesn't fit in the k-member. It's 11.620" wide at the mounts. That's about 1/4" too wide. I'm still not sure the K-member is correct. Well, it looks like I need to go out and buy a real block & heads for my fit up. thanks again.
don
I need a few more measurement to verify what else is wrong with my plastic replicate block. I made a sketch of what I need. I'm thinking I may be able machine it down to the correct dimensions. Hemirunner, I sent you a PM. IMG_2685.jpg
65AFX,
Take these with a grain of salt as they are probably within .015 but will give you what you need.
