Why would a substantial amount of water leak from this area?
kaj750
11:46 PM
Fresno, CA
So far, I have pulled my intake and rocker assemblies, removed the heater hose lines from the firewall, and remove the radiator. I have also unbolted the headers as it turns out I have to remove them to get to the lower bolts on the cylinder heads.
Today, when I raised the driver's side of the vehicle, I got a pretty substantial amount of water pouring out under the car. When I went to look under the hood, I see it running off the bottom corner of the cylinder head.
It looks to be coming from the rear most, lower header bolt hole.
Is it common for header bolts to extend into water passageways?
I will be replacing the cylinder heads with aluminum, so not sure if this will still be an issue.
I'm just wondering if the original owner used too long of a bolt and ended up cracking and/or breaking into an area he shouldn't have
A look at a bare head with the core plugs out will make it easy to understand. Unlike small blocks, all big block exhaust hardware is "wet."
I found water inside the exhaust port. The studs looked dry to me.
Both my Stealth and Eddie heads have blind exhaust stud holes. I had a leaking exhaust stud on my factory Bee heads where I had a broken stud drilled out and re-tapped. This stuff cured it for good:
I had the same issue with my heads. Even with some sealant they still leaked into the exhaust. When I pulled the heads I found the threads pretty corroded. I ended up drilling them all out and installing Time-Serts and then studs with high temp thread sealant. No more leaking and a nice tight seal.
