Flyboy1400
As the title said, for the purpose of breaking in a new engine without spinning the pump in the trans, will a 130 tooth 10.5 inch flywheel fit/work for this?
And it clears the input shaft of the front pump ok?That is what I use on my run stand.
I bought one of those, but changed my mind about building a run stand (limited space in garage). Figured I could just drop the engine and trans in the car with a flywheel to keep them disconnected atleast for the cam break in.This might be an option if don't want to hook up a transmission to start your engine on a break in stand.
383-440 MOPAR Engine Starter plate | eBay
no, nothing that out of the ordinary , just a 440/727 comboI saw the title… and thought maybe you were running an old Clutchflight.![]()
I use a gutted 727 case.And it clears the input shaft of the front pump ok?
Plus I need to fab up some exhaust head pipes and that would be easier to not mess up if the trans is in place...or so it would seem
That'sI use a gutted 727 case.
