72duster72
Wilwood six piston 13 inch front brake kit 69 road runner. I am having trouble aligning the caliper caliper slide onto a studs so I don’t see any shimming possibility like all the videos I saw any insight would be great
I had the exact problem with my same setup. Called them about it. Turns out that the early spindles they were getting were not machined correctly. The boss on the spindles is at the wrong height. Once they discovered it they now check each one before they send them out. I bought a newer set of spindles from them and returned mine for a refund. I wasn’t even the original purchaser of the front end! Excellent customer service to stand behind their product like that imo. Give them a call. Do not modify the wilwood stuff, its not the problem.Thanks for help
