Winter updates
dvw
2:37 AM
waterford mi
Been working on finishing the trailer. About as far as I can get since the rest requires welding brackets, running air and propane lines underneath. Built an oil rack over the fender, mounts to hold the cooking table (both out of $20 recylcled diamond plate), and a floor pulley for the winch. The pulley took some thought. Had to figure out how to keep the rope from falling off if it got slack. But wanted to make the the assy pull up out of the floor and slide off the rope for storage. Ended up making a spring loaded arm to capture the rope. Now just need to bore the hole in the floor and weld the reciever tube to the frame.
Doug
