wiper motor
paul1969cars
2:42 AM
new york
I put in a 3 speed wiper switch which was rebuilt and tested fine.
The wiring harness under the dash is new. I just put it in
The wiper motors was just rebuilt and i just put it in
When I turn it on the wipers they moved a little and stopped
Then with the wiper switch in off position I heard these clicking sounds from the wiper motor.
Could it be a bad wiper motor or a bad ground ? some place
I even disconnected the wiper linkage to the motor. The wipers move freely and are not binding up on anything
and I ran the wiper motor with the linkage not connected and sometimes the wiper motor ran and sometimes it didnt
and the wiper wash button was fixed as well and I tested it for continuity and it worked. I put in in car and it doesnt work. I put power right to the washer bottle motor and that motor works fine. Could it be engine bay wiring to that wiper bottle?
What could it be
Paul
Is the dash hanging out or fully installed and grounded. Wipers won't work correctly if the switch case isn't grounded
Hi
Dash is in and I grounded the switch housing to the the frame under the dash as well
