Wiring Diagram
wedgie
4:40 PM
America
Does anyone have an early B body wiring diagram that they would share? My '63 is having brake light issues. Pulled both wires from the stop light switch, One reads 12V+ the other reads open. Taking a wild guess that there is a broken wire or something in the turn signal circuit.
MyMopar should have them in the FSM free
You are on the right trail....Sorry, but can't help you with a schematic for your car but brake lights go thru the turn signal switch in the steering column as well as the multi pin connector under dash that connects turn signal switch to cars wiring harness. The brake pedal switch is the 12 volt source when brakes are applied that is then sent to the turn signal switch, then to the rear lamps. With brakes applied, the switch at brake pedal should show 12 V referenced to ground on both terminals (switch closed). If this is the case, brake pedal switch is OK and you need to check out the turn signal switch which could be the problem. Also possible that there may be a problem in wiring to rear of the car. Are your turn signals all working front & rear ?? If you go to the electrical forum here, last month or so I posted detailed info on "Turn signal switch repair, 66 Charger." May help...
