Wiring question. 70 Super Bee.
quicknick
8:12 AM
Michigan
My 70 super bee has a rallye dash, but is a clock/tach delete from the factory. If I choose to purchase and install a tic toc tach, is the wiring there for it behind the dash, or did Dodge use different harnesses? Also, are they all universal fit? I found one from a 70 Roadrunner. Will it work in my Bee? Thanks for the help on this.
I would think the power & ground connections for the tac should be there.....you will have to purchase the tac harness (a single wire) that runs from the tac through the firewall to the coil...............check your shop manual wiring diagram...will show you everything
I need to have my Tachometer repaired, original 68' charger. Any recommendations as to the best place?
