andrew kirk
New Member
- 8:51 AM
- Feb 26, 2021
- niagara falls new york 14305
We have a 1975 charger 360 was running great for hours then shut down like I turn key off we put a new alternator new fuel pump new fuel line new sending unit I changed the fuel filter and put a clear one on so we can see if there's fuel moving through the filter we have fuel going to the carburetor it's turning over it just seems like I totally lost fuel or spark if I hold it to the floor it will start up and stall immediately any suggestions on where I should start it's an elder block 4b but it's all stock except carb.update if hold it to the floor it will start sounds like it's being choked out everything sounds normal expect choking out part so got spark got fuel going
