Check with Glen Ray on your radiator, he’s the best for MoPar radiators. Costly but well worth it.
http://www.restorationradiators.com/
Guy #2: By the way, can you lend me $50, I'm a bit skint at the moment...Guy #1: "Look at my new belts I bought from Year One".
Guy #2: "Look at the survivor belts I bought from a parts collector that matches my survivor car".
Guy #1: "I'm not worthy, I'm not worthy!"
The repops were throwing off pretty regularly also. So a repop must be just as bad as a 50 year old belt. You can't win!Just make sure you get the proper attaching brackets on the 26 bbody rad as this will determine if the correct shroud will attach to rad, there are a few different ones out there as for other same year mopars,get a good reference pic n compare.
Not sure what you are refuring to about belts,but i was talking about the supports that are soldered on top n bottom of tanks,they have the mounting bolts attached to them and if you have the proper ones there is no problem attaching the correct shroudThe repops were throwing off pretty regularly also. So a repop must be just as bad as a 50 year old belt. You can't win!
My mistake! I mixed up my quoting. Apologies.Not sure what you are refuring to about belts,but i was talking about the supports that are soldered on top n bottom of tanks,they have the mounting bolts attached to them and if you have the proper ones there is no problem attaching the correct shroud
