SOLD WTB 1966 Coronet/Satellite or Charger
1970beep
9:19 AM
Wales, Wisconsin
Feedback: +4 / =0 / -0
I am in need of a 1966 B body parts car. Must be a 318 poly automatic with an 8 3/4 rear end. I need the driveline to be complete with all linkage in place for the engine and trans.The engine need not run and the trans need not be working but the rear end must be working. I do not need any other parts as this is to be a donor for a project vehicle.
A floor shift automatic would really be great.
Prefer near SE Wisconsin.
I may be able to use a 1967 B Body but 66 would be best as I am using a poly engine in my project and would like the linkage pieces to use.
Thanks,
John
I have all this I dropped out of a 66 coronet on my garage floor. Disconnected linkage from collum and accelarotor from carb and dropped k frame complete assembly. Also have a couple 66 8.75 rears.Never shipped anything this big so not sure its feasible. Maybe an option if nothing local turns up.DD
I have a complete 66 R/End drum-drum, also might still have the drive shaft! It is still under the car! have a floor shifter with linkage. I'm located in the St. Louis area
Hoping for something a little closer but if nothing shows will keep both of you in mind. Not sure what shipping would run.
John
Too bad you're not down here. I know where there are two poly 318 Coronets that they can't give away parts from. Both have compete drive trains. I'm actually surprised that the 8 3/4 s are still there. If they stay much longer, I'm gonna have to go get them myself.
What "project" are you putting a poly in?
I always liked my poly cars. I think they are a torquier motor than the LA 318.
The downside is that they look like a big block, and chevy guys are quick to scream that whenever they get beat by one.
