FOR SALE wtb 4spd change over parts
jimsbee
7:59 PM
pa
Hi looking for the following parts to convert my 68 coronet from an auto to an manual.
Bracket for zbar one that mounts to trans
Clutch fork
Clutch rod that goes from zbar to the clutch fork
Aluminum flywheel 6bolt
An clutch for a 10 1/2 bell housing
brewers performance has everything you need
Checked them out figured I would see if anybody has them here first then I'm gona give them a call.
alot of those items are consumeables and i would recommend getting new, to be safe
All those parts need to be correct and compatable. Very easy to mi-match with used parts. Brewers is the best in my opinion and can answer all your questions...........................MO
Just so you know a 68 would have used an 11" cast iron bell housing factory. Not a 10.5".
Matt
Yea I know the 10.5 bell isn't what 68 had but I'm piecing this swap together and not really worried about correctness, car is a hot rod anyways
I bought the bellhousing from brewers that has dual starter locations. takes either the 10 1/2 or 11" flywheel/clutch. Opens up the options. I got tired of the 11" and put a 10 1/2" in. It's lighter and revs faster.
