WTB WTB '68-70 B Body Driver's Door Striker
james j
2:40 AM
Chicagoland
Feedback: +0 / =0 / -0
Hi Everyone,
I am in the process of setting doors on my project (’68 Charger), and found my driver’s side door striker to be pretty messed up. The three mounting bolts were up-sized by the previous owner and two of them broke off upon removal (before stripping). These bolts also enlarged and rounded out the through holes on the striker plate itself. I’ve already searched through these forums and eBay, but haven’t found much luck. If anyone has an extra, 68-70 B body, driver side striker plate, any help would be greatly appreciated.
All the best, and thanks in advance,
James
sounds like you are referring to the door latch it fastens to the door with 3 countersunk screws.
the striker is the shouldered bolt on the door jamb which the latch catches.
you might post an image so we can see?
I have door latches from a 4 door 70 Satellite if that is what you are needing and if they would fit for you would have to check for application.
Yes Rodney, you are correct. Thank you. I am in need of a driver's side, door mounted latch, and a few extra of the counter sunk screws if possible! :-) Happy New Year!
