WTB WTB big block pulleys and brackets
ragtp66
7:30 PM
Chicago
Feedback: +0 / =0 / -0
I have a 73 440 pulled from an Imperial that was an AC car. I need a complete set of big block pulleys and brackets for power steering, alternator, water pump and also water pump housing & water pump if needed. The key is it needs to be a cast crank set up. Let me know what you have.
Chris
If I remember correctly, the water pump housing had the outlet on the passenger side in 73. If you are using this motor in an older car, the outlet was on the left side. (driver side)
What are you installing this in? A/C or non?
water pump and power steering pump
Hi have you found the parts that you needed yet? I have a big block set if interested PM me. Am still looking for the triangle alt bracket but here are some pictures of what I have at this time. I removed the power steering pump and waterpump housing from my R/T when I converted to manual steering. $75.00 for both plus the shipping. I'll throw in the hi pressure hose too.
