FOUND Yoke Bolt or bolts 1/4" x 28 x 5/8" long bolt
Fran Blacker
1 of 27
9:24 PM
Connecticut
Feedback: 20 / 0 / 0
Still doing dumb things. Unbolted u-joint straps I use to lift rear on/off sawhorses while work on rear. Just started screws back in yoke, error. Dropped on to jack to roll under car and it nosed over and bent this bolt, so here I am hat in hand looking for a OEM bolt to replace this bolt. Has sort of a triangle in center of head, an H in center is ok but I'd like 2 of those so all 4 are the same. Two others have an H and 2 look like this.
If you have 5 bolts I'd buy them.
Hey Fran - If no one here has any, try Byron Fettig (The Dakota Connection) http://www.mmcdetroit.com/THEDAKOTACONNECTION/ He has dismantled hundreds of cars and co-wrote the Mopar fasteners guides with David Wise for MMC Detroit. He is an expert on hardware and may have what you need.
Yes he does list them, I'll wait a few days. Thought I was on home stretch on putting a SG in my 8.75 and beat the cold temps.
If you don't need originals right away TSC farm Store and even Lowes and Home depot have large selections of Hardware to get you going in the mean time...
Bolt or bolts anyone?
I have 2 that look like the triangle ones you speak of?
I also have a set of 4 bolts with the small heads.
I am looking for 2 "H" headed bolts myself.
I would trade the 2 big heads or 4 small heads for your 2 "H" headed bolts.
If your interested start a private conversation.
Thanks! John
Thanks for the offer but I need H heads or one that looks the same but sort of a triangle.
